2005 A6 GPS
If you search the C6 A6 forum in audiworld, you'll probably come across someone that did this install. He didn't quote any prices, but I guess it will probably run you $1500+....would be my guess. Check with the dealer for the appropriate part#s and costs. From what I understand, you just need to purchase the Nav drive (I believe your 4.2 will have the GPS antenna already built into the submarine fin on the roof) and plug it into the drivers' trunk area. You'll probably need to use a VAGCOM to program it.
Good luck!
Good luck!
ok. ...this link should help too.
http://shop.kufatec.de/index.php/cPath/2_111
see the 2nd item for 749 Euros.
Good luck!
Good luck!
Blackpaw
B7 Models
Mar 4, 2008 11:58 PM
