2005 A6 timing
Old Feb 17, 2008 | 02:35 PM
daredevil1's Avatar
Default 2005 A6 timing
Does a 2005 A6 3.1L have a timing belt, timing chain, or both? Thanks
Old Feb 17, 2008 | 03:59 PM
Kevin's Avatar
Default RE: 2005 A6 timing
timing belt
Old Feb 18, 2008 | 10:38 AM
daredevil1's Avatar
But this article says it's chain driven:
http://www.dpncanada.com/index.php?o...d=455&Itemid=2
Old Feb 18, 2008 | 05:20 PM
Kevin's Avatar
The 4.2 has a chain, the 3.2 has a belt.
Old Feb 18, 2008 | 05:35 PM
Batteries's Avatar
ORIGINAL: Kevin
Yeah, you're probably right, since you usually are, but it is confusing. That article says that *both* engines (3.2 and 4.2) are chain driven.....?
Old Feb 18, 2008 | 06:06 PM
daredevil1's Avatar
Oh ok, thanks!
Old Feb 18, 2008 | 07:36 PM
Kevin's Avatar
I have an 05 4.2 that certainly has a timing chain. The generic A6 service manual that came with the car calls for the timing belt in the 3.2 being replaced at 75,000 miles. It is possible that the service manual is wrong, or has a typo, but it does seem to indicate that the 3.2 has a timing belt. However, the 2005 brochure for the 3.2 says that it has a "maintenance free chain drive timingbelt". So the mystery continues.
Old Feb 18, 2008 | 10:23 PM
Batteries's Avatar
Here's the "official" 2005 Audi A6 Sedan Equipment list. As Kevin said, it states that both have a timing chain....?
Old Feb 28, 2008 | 06:42 PM
daredevil1's Avatar
Even if it does have a chain, how can it be maintenance free? Chains can still wear out and break. And what does chain drive belt mean?
Old Feb 28, 2008 | 07:10 PM
auditech79's Avatar
Both the 3.2L and 4.2L engines have timing chains. The ONLY motor that still has a timing belt after the year 2005 is the 2.0T, the early model 4.2L A8's still have belts until they upgraded them to FSI 4.2L chain drive motors as well.
The chain would take well over 500 thousand miles before it would ever need service, its no standard steel chain.
