95 A6Q coolant sensor replacement
Old Nov 17, 2009 | 03:16 PM
altonachrome's Avatar
Default 95 A6Q coolant sensor replacement
Anyone have any suggestions/tips on the sensor replacement. Mine is constantly going off even when engine is started cold. I've checked coolant temp. and it's normal so I'm assuming the sensor is bad.
Old Nov 18, 2009 | 08:31 AM
s31523's Avatar
Not sure where yours is located. On mine ('02 A6 3.0L) its under the big accordion-like air intake hose. Its a bit hard to find. It is cheap (for mine). You might need to go to the dealer to get an O-ring and U-clip (which I am told are good to replace and cost $2.00, even at the stealership). I got mine here:
http://www.rockauto.com/
Tiyal
Feb 24, 2011 05:15 PM
mikeeboy82
May 2, 2009 11:12 PM
gtzpower
Feb 9, 2008 02:53 PM
thetryal
Jul 11, 2007 08:46 PM
banderson121
Feb 28, 2007 09:26 PM
