Sponsored by:
Sponsored by:
95 A6Q failed inspection
Old 02-02-2011, 01:50 PM
altonachrome's Avatar
Default 95 A6Q failed inspection
My wifes 95 A6Q failed its yearly inspection because the inspector said the e-brake is not engaging on the right rear caliper? I replaced both e-brake cables one year ago and the cables are fine. When car was in the air you could see where the outer surface of RR rotor is covered with light rust/road grime where outer pad apparently is not making proper contact. However, the inner portion of said rotor is nice and shiny clean as it should be. Any thoughts and/or suggestions. Is it time to rebuild/replace said caliper?
Many thanks for any help!
1995 A6Q 2.7 150,210
Old 02-02-2011, 05:07 PM
bob martin's Avatar
You got it.
Bob
Old 02-05-2011, 04:38 PM
Thanks Bob, that's what I thought. In a moment of obvious lunacy l was thinking that there might have been an "easy fix".
Old 02-06-2011, 08:11 AM
bob martin's Avatar
Replacing a caliper is easy. If you think not, try replacing the spider pipe, or cam seal, or t-stat, or ....
Bob
Old 02-08-2011, 06:19 PM
Bob, about how much time should I expect to put into changing out the caliper?
Old 02-08-2011, 09:44 PM
chefro's Avatar
If you have all the bolts pre-sprayed with penetrating lubricant - especially the one attaching the break line to the caliper (so no unwanted holds) I would say 2 hrs tops, for a neat/perfectionist freak...including cigarette and beer breaks.
niknak's Avatar
It's not so much the time, but the cost to replace a caliper!
Old 02-09-2011, 01:56 PM
NH_USA's Avatar
get a rebuilt loaded caliper from Force Five for a bit over $100..
billyburgos
08-04-2015 09:05 AM
suhail82
03-01-2010 09:13 PM
theTTkid
02-02-2009 05:19 PM
theTTkid
02-01-2009 06:48 PM
Bbarn
06-01-2006 12:26 PM
Quick Reply: 95 A6Q failed inspection
