95 C4 A6 Cruise control not working
Old Jun 8, 2012 | 08:10 PM
L_U_D_I_AAudi's Avatar
Default 95 C4 A6 Cruise control not working
Hello everyone...
I am fairly new to the audi world and has hoping someone can help me diagnose my problem... the cruise control on my 95 C4 wagon does not work. Does anyone know where the actual cruise control module is located? Is it power operated or vacuum operated? I have checked all the fuses and everything is OK but the cruise will not operate. One thing to keep in mind is that the ABS light is on due to bad front ABS sensors. Is the ABS system in any was associated with the cruise control? I did some research here on the forum but could not find anything on the C4.
Thanks in advance for the help!
Old Jun 8, 2012 | 10:13 PM
Joe Edgerton's Avatar
Brake light switch effects my cruise control
Old Jun 9, 2012 | 12:10 AM
so do you mean that the brake switch will affect the cruise control? if there is something wrong with the switch doesn't that mean that the brake light will not come on once the brake pedal is pressed?
Old Jun 9, 2012 | 06:28 PM
No I have led bulbs and my car doesn't recognize the low Wattage so it says I have a brake out but I really don't. if you have something effecting your brakes the cruise won't work because its used to regulate speed going down hills
Old Jun 9, 2012 | 11:49 PM
well I do have 2 bulbs that are burned on my 3rd/roof brake light but still I have no "brake light" bulb warning on my message center screen... I should probably assume that its the abs sensors then
Cephyr13
Sep 5, 2011 09:14 AM
IvDogg
Jun 3, 2010 07:41 AM
xIlluzionx
Jun 19, 2009 11:52 PM
lopez371000
Feb 6, 2007 10:31 AM
