Cruise Control Not Working - '97 A4 1.8T
Old Sep 1, 2011 | 09:09 PM
Cephyr13's Avatar
Default Cruise Control Not Working - '97 A4 1.8T
My cruise control has gone out in my A4.
Is this a common problem?
How would I go about troubleshooting this?
I checked the vacuum hoses to the cruise control unit. They seem to be fine. The linkage is attached to the throttle body. I can't visually find anything wrong with the cruise control.
Thanks so much for any help you can provide.
- Brian
Old Sep 4, 2011 | 03:40 PM
ImTheDevil's Avatar
Likely your control stalk on the column is dead. It's not that uncommon. There's also a control module above the glovebox that can get cracked solder joints. Heating the board to re-lay the solder sometimes fixes it but my bet is the column switch.
Old Sep 4, 2011 | 10:36 PM
Blayne's Avatar
Not 100% but there should be a fuse for your cruise control. Make sure it is good!
Old Sep 5, 2011 | 09:14 AM
Cephyr13's Avatar
The fuse for the sunroof has been removed, because there was a problem with the sunroof. Are the sunroof and cruise control on the same fuse by chance?
If it's not the fuse, then I imagine it's the column switch like Devil said. Thanks!
L_U_D_I_AAudi
Jun 9, 2012 11:49 PM
IvDogg
Jun 3, 2010 07:41 AM
xIlluzionx
Jun 19, 2009 11:52 PM
lopez371000
Feb 6, 2007 10:31 AM
