98 A6 engine dies when idling
Old Jan 24, 2011 | 04:18 PM
divil's Avatar
Default 98 A6 engine dies when idling
Lately when the engine has warmed up, it can't idle properly - if I let it idle it cuts out. I can start it back up again but have to keep my foot on the gas to keep it running.
After waiting 20 minutes or so it seems to work OK again.
It's a 1998 2.8 V6. Also, a few weeks ago it gave the opposite problem, where for a short time it was idling really high, around 3000rpm. This only happened once, for about 10 minutes.
Any ideas what I can do to fix it? I used a code reader to read the fault codes but all it found was related to the secondary air pump and the brake light signal, which I didn't think would be related to this issue.
Any help greatly appreciated!
Old Jan 24, 2011 | 05:05 PM
S_lineA3's Avatar
I had this happen to my 2007 A3. Turned out to be the "low fuel pressure" sensor. Had it replaced and fixed.
Old Jan 24, 2011 | 05:06 PM
02A6Beau's Avatar
try the MAF first
Old Jan 26, 2011 | 10:18 AM
oldmots's Avatar
My first look would be the intake system integrity, be sure there are no leaks between the MAF and the throttle body. This will cause a lean condition that creates a rough, thready idle. The secondary air system could be leaking too, check it out also.
Audinick81
Apr 17, 2015 10:54 PM
honning57
Oct 3, 2014 05:54 AM
acollicott
Jan 9, 2008 11:49 PM
DavidElvin
Apr 19, 2007 01:04 PM
Madcrazy10
Apr 6, 2006 02:26 PM
