98 A6 wont start need help
Old Oct 25, 2010 | 04:38 PM
skinwalker78's Avatar
Default 98 A6 wont start need help
Ok I have a 98 Audi A6 and now it wont turn over....I have replace the alternator, ignition switch, check the ground wires only found the main one to the frame to block and like 4 tan ones on the driver side. even tried to jump it nothing. Do you think it is the Starter or electical issue? Please help and thanks
Old Oct 25, 2010 | 05:33 PM
oldmots's Avatar
Does anything happen when you turn the key?
Old Oct 25, 2010 | 05:48 PM
Yeah when I turn the key everything comes on dashlights, headlights, have power to everything just wont turn over for some reason
Old Oct 26, 2010 | 02:41 PM
bob martin's Avatar
Most likely the starter. Could be a neutral safety switch.
Good luck,
Bob
Old Oct 26, 2010 | 04:17 PM
Theiceman's Avatar
it's either gonna be ignition switch starter solenoid or starter motor .. but check to make sure your bat connection and grounds are tight ..
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
