99 A6 electrical problems
Old Jan 27, 2007 | 05:36 AM
mjsell6's Avatar
Default 99 A6 electrical problems
I have an 1999 A6 quattro with a few electrical problems. The power door locks and interior lights do not work. Also, the back-up lights occasionally come on when I am in drive.
Any suggestions?
Old Jan 27, 2007 | 02:51 PM
Jeffla's Avatar
Default RE: 99 A6 electrical problems
I would guess that your PRND switch(who knows what is real name is) is probably sticking, causing the reverse lights to come on when they shouldn't. A fuse is my only guess as to door locks and lights.
Old Jan 27, 2007 | 06:15 PM
mpw2.7T's Avatar
Check fuse 14. Any other symptoms? Display showing 3 open doors?
Old Jan 31, 2007 | 10:51 PM
mjsell6's Avatar
Thanks for the tips. I was able to figure out the back-up light issue--thanks. I replaced fuse 14, however, still no dome lights or locks. Any other suggestions?
Old Feb 2, 2007 | 02:32 AM
chinaloy's Avatar
I remember reading that the locks and lights may not work due to the door switches. apparently there is some insert that breaks. Somewhere someone has home made fix. You will have to search for it. The entire switch assembly seems to be very expensive.
Mercy404
May 2, 2015 09:22 PM
Jimbezy
Mar 24, 2009 08:23 PM
kraiv
Jun 28, 2008 03:48 PM
02A418T
May 1, 2007 10:57 PM
baba
Mar 12, 2007 03:02 PM
