99 a6 p1545 p0300
Old Aug 21, 2011 | 08:36 AM
gerberbaby's Avatar
Question 99 a6 p1545 p0300
I have a 99 A6 2.8. I replaced the timing belt and valve cover gaskets and now I get codes P1545, P0300,P0303,P0302. The car will start but barely runs and backfires slightly. Car was running fine before I started. What have I done? I do have the camshaft alignment tool and crank marking is right on the arrow.
Old Aug 21, 2011 | 08:53 AM
bob martin's Avatar
You have some electrical connection undone or crossed. Or, you have a massive vacuum leak due to an intake hose not connected. Go over it again slowly.
Bob
Old Aug 21, 2011 | 11:27 AM
gerberbaby's Avatar
Could I have messed up something with the fuel rail cyl 1-3 when I lifted it a bit to put remove the valve cover? Injectors are plugged in so it looks ok. I also cleaned out the PCV components, which is what started this nightmare,
Old Aug 22, 2011 | 06:06 PM
bob martin's Avatar
Yes, you could have messed up one of the o-rings that seals the base of the injector to the head. Spray carb cleaner in the area while idling the car. If the idle drops, you have found your problem.
Old Sep 21, 2011 | 07:31 AM
gerberbaby's Avatar
It turns out the throttle module needed to be reprogrammed. I had the battery disconnected for a few weeks and the TM didnt reset. Lesson learned, if the repair manual doesnt tell you to disconnect the battery, don't do it! At least not for long periods of time.
retrodriver
Jun 28, 2018 12:34 PM
gilraine
Mar 31, 2012 07:42 AM
elye1231
Jul 6, 2011 10:58 AM
jonzo
May 18, 2011 01:15 PM
mr.cAp
Sep 14, 2008 09:01 PM
