A6 2.7T Engine Error Code HELP!!!
Old Apr 9, 2009 | 12:39 PM
twinturbosixer's Avatar
Member
Exclamation A6 2.7T Engine Error Code HELP!!!
Hello,
My 2001 A6 2.7T has an engine error code coming up and was hoping you guys could help me identify how to fix it.
The error code is: P0117 (engine coolant temp circuit low input).
The car has 122K on it. I dont know much when it comes to under the hood. Body work is what I am more into, so I am kinda in the dark on this one. If anyone can help me out id appreciate it!
Old Apr 9, 2009 | 04:44 PM
madtec's Avatar
Check your temp sensor voltage signal
Old Apr 9, 2009 | 05:22 PM
Member
any chance you can tell me where that is located?
Thanks for the input, its much appreciated!
Old Apr 9, 2009 | 09:17 PM
TwinTurboC5's Avatar
Default Engine Error Code P0117
Hi, Twinturbosixer
The problem and code you're describing is telling me that you have a bad "Engine Coolant Temperature Sensor". It should be located and threaded into the rear coolant line. This line is located at the rear of the engine towards the top. The sensor should be threaded into the right side of the line near the firewall (left if your facing the car). You probably will have to remove the plastic intake duct and metal Y-pipe to see and get to it. Its a fairly easy part to replace, just get the part, disconnect the wiring connector from the old one, and don't forget to wrap a little plumbers tape on the threads before installing the new one...then reconnect the wiring connector. After that you simply top of the coolant recovery tank to replace any coolant lost during the replacement. Good Luck with it.
Old Apr 10, 2009 | 12:47 AM
madtec's Avatar
Thanks twinturboC5 for your input, i am mainly a nissan guy and still learning about my audi
Old Apr 14, 2009 | 01:55 PM
Member
yes, thank you twinturboc5 really appreciate it!
Untouchabl3
Jun 6, 2011 02:33 AM
smoovmusicdj
Jun 16, 2008 09:51 PM
smoovmusicdj
Jun 16, 2008 08:06 PM
davetec
Nov 3, 2007 01:05 PM
gordond
May 11, 2007 05:11 PM
