A6 2.7T - metal brake lines?
Old Apr 23, 2007 | 10:03 PM
ppgoal's Avatar
Default A6 2.7T - metal brake lines?
I searched this forum for information on replacing the OEM brake lines with metal, but although a couple posts mention doing it, there was no information on parts kits or sources. I'm thinking of doing this when I have my brake fluid changed.
Has anyone recently replaced all their brake lines? Were you able to find a kit or did you make (size) the lines yourself?
I've seen kits for the A4 but none for the A6. Any [constructive] advice would be appreciated.
Old Apr 24, 2007 | 01:46 AM
slee22's Avatar
Default RE: A6 2.7T - metal brake lines?
ECS has them: http://www.ecstuning.com/stage/edpd/...category=Lines
Old May 6, 2007 | 08:33 PM
ppgoal's Avatar
Default RE: A6 2.7T - metal brake lines? ECS?
Thanks for the reference. Follow up question: Has anybody used the ECS brake lines or any other stainless steel brake line? If so, did it firm up the pedal? Any fitment issues?
Old May 7, 2007 | 02:51 PM
votblindub's Avatar
theres 0 need to replace lines with braided lines unless its a track or autocross or a generally race car. you'll be wasting money, just use OEM if yours are won out
Old May 7, 2007 | 03:57 PM
fusnowtiger's Avatar
However, the braided steel ones are less expensive than OEM (especially from a dealer).
Old May 10, 2007 | 11:14 PM
ppgoal's Avatar
I've got the coin, because I'm the idiot who finds the car runs the same on midrange gasas premium. And since I'm going to have the brake fluid flushed as is called for at 80k miles, I figured I'd replace the lines at the same time since the car has 96k miles.
To reiterate - has anyone installed stainless steel braided lines and what is the driving experience?
Old May 11, 2007 | 08:54 AM
votblindub's Avatar
ORIGINAL: fusnowtiger
if its cheaper and better than oem at the same time, id do it up
Old May 11, 2007 | 09:04 AM
techbod's Avatar
the braided ones are the flexies not the system lines original are high pressure rubber which need to flex with turning and suspension movement so steel would break in no time,
which are we talking about? flexi or system lines
Old May 11, 2007 | 05:26 PM
votblindub's Avatar
im thinking the braided ones that go from the metal tubes into the calipers
vgo
Jan 16, 2010 02:12 PM
punjabi
Nov 3, 2009 08:59 PM
NeXeA500
Mar 21, 2009 12:15 PM
oczalevsevy
Mar 20, 2008 07:29 AM
ADubyaD
Oct 19, 2006 03:05 AM
