A6 2.7Turbo - Ignition problems
Old Aug 16, 2006 | 12:11 PM
mholm's Avatar
Default A6 2.7Turbo - Ignition problems
Hi guys,
I drive this wonder car (Mileage 106.000) but recently experiencing some problems getting it going. I turn the ignition and it starts instantly only to fade out and switch off after a second or two. I keep trying and after 3-4 attempts it starts and drives perfectly. What is wrong with this thing? Please help!!!!
Old Aug 31, 2006 | 03:23 AM
hobart's Avatar
Default RE: A6 2.7Turbo - Ignition problems
Best advice purchase a VAGCOM and CD formated manual. Read the fault codes and you will most likely find your answer.
Old Aug 31, 2006 | 04:06 AM
SouthboroAudiGuy's Avatar
ORIGINAL: mholm
Hi guys,
Trying to diagnose this issue with the amound of info you provide is like trying to do surgery over the phone. Suggest you check the appropriate regional forum here or on audiworld.com to find a good, well respected independent mechanic who specializes in Audi. Have them take a look at it. When you're dealing with a more specific problem, c'mon back. We'll leave a light on for ya.
Old Sep 2, 2006 | 12:49 AM
norcalAudi's Avatar
This may be very left field but that sounds like what happens when you try to start the car with the plastic key. Possibly the battery in your transponder key is going out and the car is not receiveing a signal from the key?
Indianabob
Jan 8, 2012 06:57 PM
punkrocker5817
Nov 18, 2008 09:30 AM
ckim1021
Jul 1, 2008 09:06 PM
perzianhustla
Sep 23, 2007 09:07 AM
CaliA4
May 7, 2007 02:48 AM
