A6 2.8L Strange Mist (Smoke)
Old Nov 5, 2006 | 10:54 PM
nexuspr's Avatar
Default A6 2.8L Strange Mist (Smoke)
Hi, my audi A6 2000 2.8L has a strange mist coming from the hood every morning on my way to work, It happen's in the morning when the engine's cold, but after that, the rest of the day, runs just fine, no smoke at all, my car has a oil leak that I'm about to fix, could that be the problem???
thanks
Rene.
Old Nov 7, 2006 | 01:26 PM
zebinheimer's Avatar
Default RE: A6 2.8L Strange Mist (Smoke)
how heavy is condensation in your area in the morning? that could be it burning off unless its a real thick mist, then im not exactly sure
Old Nov 7, 2006 | 08:26 PM
prbayha's Avatar
If its oil, you'll know it..It stinks real bad and is unmistakable.
Old Nov 7, 2006 | 08:41 PM
techbod's Avatar
is it the oil ?? you tell us im sure that's simple enough
Old Nov 7, 2006 | 09:18 PM
nexuspr's Avatar
The mist isn't that thick , but its noticeable just every morning coming out of the hood, not a lot of amount but I can see it coming from the driver side of the hood and passenger's side also, even down on the front bumper, It doesn't have an odd smell, the smell is like coolant, but my car's temperature is just fine, my car's mileage is 71,000. Next week I have an apointment with my mecanic, Im going to do the timing belt, water pump and the hole enchilada, even Im going to change the thermostat and do a radiator flush then add brand new coolant. Is there something else I might be checking, even though Im going to ask my mecanic about the problem, I want to know you're point of view guys, what could be the strange mist?
thanks again
Rene.
Old Nov 7, 2006 | 09:21 PM
techbod's Avatar
if its a sweet smell its coolant and chances are its the water pump and good luck
Old Nov 7, 2006 | 10:16 PM
nexuspr's Avatar
Thanks for your help, Next week I'll get the water pump replaced , with the timing belt works and the thermostat, It should get it fixed
thanks
CCA4
Jul 7, 2012 12:26 PM
///MPower
Nov 8, 2008 06:23 PM
True_Pinoy
Mar 27, 2008 11:51 AM
Palindari™
Dec 10, 2007 06:02 PM
