A6 2000 T front and rear indicators stay on
Old Feb 27, 2008 | 04:42 PM
newbhoy's Avatar
Default A6 2000 T front and rear indicators stay on
hi there,havent seen this problem on the forum yet. A couple of weeks ago my front and rear indicatorlights came on and stayed on, they werenot flashing or anything but my battery was flat in the morning.{Also the hazzard warning switch on the dashboard was also lit up}.So i took it to the garage and the mechanic disconected the battery, kept it for a couple of days, got it working then gave me it back but said he didn,t know what was wrong with it although he thoughtitmight bea problem with my alrm system. Well now its happened again and i havent a clue what the problem is. I would be really gratefull for any advice.heers
Old Feb 27, 2008 | 05:26 PM
james0013's Avatar
Default RE: A6 2000 T front and rear indicators stay on
This is just a guess, but there is an electrical relay behind the hazard switch on the dash. If the lights are staying on even when the ignition is off this points to a circuit that is permanently powered being the problem, the hazard warning lights are one such circuit. If the relay has gone bad it could be sorting and making the lights stay on.The intermittent nature of the fault points to a relay this is in the process of going bad but not yet completely shot.Are the indicators (turn signals) still working?
This means removing the panel around the cup holder/buttons (orcoin draw)and changing the relay. You can get one from a steelership or ebay and try that.
If you go to www.audidiy.com and look at some of the tutorials about installing a passport radar detector they will tell you how to remove the panel in the dash.
Best of luck
James
hartsoe1
May 25, 2013 05:26 PM
v diaz
Mar 9, 2010 09:32 PM
Jackmup
Apr 8, 2009 05:51 PM
audi_a3_1st_timer
Nov 18, 2008 02:23 PM
Topedout600
Sep 12, 2006 04:26 AM
