A6 4.2l 2003
Old Mar 28, 2009 | 06:01 AM
audispinner's Avatar
Talking A6 4.2l 2003
I recently have noticed that my A6 4.2L 2003 has recently been winding alot more than usual. It currently has 64000 on the odometer and has had a recent oil changed. Also, I live in a hilly area and as a automatic has been reving high before shifting. should I have any concern regarding a spinning noise a little more noticeable than usual? My warranty is going to expire in July and wanted to take care of any precautionary things that may go out on the car during this mileage. Any input as to the things I should watch for on this year and model will be greatly appreciated. Thank you in advance for your responses.
Old Mar 28, 2009 | 07:53 AM
Kevin's Avatar
Has the timing belt been changed?
Old Mar 29, 2009 | 03:03 PM
Default a6 4.2L 2003
The timing belt has'nt been done yet. Does it need to be done by 75K? Thanks for the advice.
Old Mar 29, 2009 | 08:32 PM
a6xlr8s's Avatar
Im pretty sure the 4.2 has a chain not a belt. As far as belts go, even though audi says 100k I do them at 80k. Ive seen cracking at 75k too. As far as the winding have the tiptronic board checked. Its found in the center console under the shifter. It can make the shift hold way too long. Is the winding the same at all engine temps? If it happens more when its cold could need trans fluid changed. Again even though its synthetic and sealed for life it is good to changes it on these cars that put out 300 / 300. Good Luck!
fast euro
Apr 3, 2010 12:13 PM
Stella Monkey
Sep 17, 2009 05:32 PM
deadmcdowell
Aug 30, 2007 03:13 PM
abacab
Mar 24, 2006 01:03 AM
rendezvous97
Jul 11, 2005 05:02 PM
