A6 Avant 2002 Camshaft ,, Help needed!
Old Sep 15, 2009 | 01:29 AM
Nawf's Avatar
hxgaser: awww thanx a lot man! that was really helpful .. really really .. tomorrow i will get the code ( hopefully only one ) and will post it so Jeffla can solve everything through his crystal thingy
No really, thanks again
Old Sep 15, 2009 | 01:54 AM
Midniteoyl's Avatar
Originally Posted by hxgaser
Ohh, ohh, ohh, did you know that there is no work gullible in the dictionary? I learn new things everyday!
gullible
One entry found.
Main Entry: gull·ible
Variant(s): also gull·able \ˈgə-lə-bəl\
Function: adjective
Date: 1818
: easily duped or cheated
— gull·ibil·i·ty \ˌgə-lə-ˈbi-lə-tē\ noun
— gull·ibly \ˈgə-lə-blē\ adverb
http://www.merriam-webster.com/dictionary/gullible
One born every second....
Old Sep 15, 2009 | 12:57 PM
NH_USA's Avatar
And I thought gullible meant that he knew Jonathan Livingston Seagull and he was able to fly like a gull.
Or maybe he proved that a gullible was eatable.
In any case do the scan thingy. You'll learn a lot.
Old Sep 15, 2009 | 03:33 PM
Nawf's Avatar
Exclamation
I did .. i took it today to an autozone and the reading said:
( P0343) : '' CAMSHAFT POSITION SENSOR A - BANK ONE CIRCUIT HIGH INPUT''
what does it mean ?
Old Sep 15, 2009 | 04:07 PM
NH_USA's Avatar
You had to know that the MIL was related to a camshaftwhen you started this discussion.. You should have given us more info in the beginning.
Mother nature and the guys with crytal ***** don't like to be fooled with.
16727/P0343/000835 - Camshaft Position Sensor (G40): Signal too High
Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Wiring from/to Camshaft Position Sensor (G40) faulty
Timing misaligned
Possible Solutions
Check Wiring from/to Camshaft Position Sensor (G40)
Check Camshaft Position Sensor (G40)
Check Timing
See. It's easy! Probably the sensor but it might be the wiring.. Have fun!
Old Sep 15, 2009 | 06:38 PM
hxgaser's Avatar
what does it mean ?
Did someone change timing belt and/or waterpump recently?
Old Sep 15, 2009 | 08:50 PM
Midniteoyl's Avatar
I was waiting for the code, but...
I own an a6 2002 Audi avant and lately ive been having a lot of problems with it so i took it one week ago to the agent and paid a top dollar to fix all the problems it had. Two days after that, a symbol popped up into the dashboard.
What was wrong and what was fixed? It sounds like the camshaft sensor is either bad or the connection came loose. I believe 'Bank One' is one the passenger side. Take a quick look to see if you can find it (take the covers off) and if not, take it back to the shop who did the work.
BrianG250
Aug 23, 2013 02:30 PM
BrianG250
Aug 23, 2013 09:59 AM
jpwheelin07
Oct 15, 2010 03:59 PM
imm_audi
May 7, 2009 02:14 AM
