A6 Brake Warning Light
LMFAO what would we do without out audis....
have you checked the fuses? I I think your runnin a c4 so I'm not sure if it has the same wheel setup but Ive had the wheel speed sensors give me a hell of a time before.
What's an an-om-aly?
I've heard of dark allies, and dead end allies but don't know about an-om allies!
Maybe he meant audi allies that can become dead end allies -- Hmmmmm.
See #31.a deviation from the common rule, type, arrangement, or form.
2.someone or something anomalous: With his quiet nature, he was an anomaly in his exuberant family.
3.an odd, peculiar, or strange condition, situation, quality, etc.
4.an incongruity or inconsistency.
5.Astronomy. a quantity measured in degrees, defining the position of an orbiting body with respect to the point at which it is nearest to or farthest from its primary.
6.Meteorology. the amount of deviation of a meteorological quantity from the accepted normal value of that quantity
Start checking Ground wires???..do you know how many ground wires are on an A6? Give us a diffenition of what this means...yaall.
OK so after plenty of head scratching (yes and the splinters that go with it!!) It seems to be an earth problem with the drivers side interior light switch which has now been taken out of its "home" and left inside the door pillar with an earth wire attached to the door and the interior light switched off in the car.
Will try the fuse box, but the good news is that the light has not come on for 3 days now!!
My guess it that it has something to do with dirt and earth!
Maybe in his door!
He probably needs to reconnect his earth at the door.
hmmm..was the above directed to be help the OP with their issue?
sorry to jack this thread, but I have an 04 A6 s-line and the e-brake light flashes and beeps when its cold outside everytime i turn to the right and accelerate. Any ideas? or does this mean my fluid is low since it only does it while everything is cold. Soon as I drive it more than 15 minutes and warm it up (ie...brakes, engine, cockpit) it won't happen again.
Any help !please! its super annoying
Thanks in advance ~ Ben
