A6 Bulb change
Old Dec 4, 2007 | 10:05 PM
topj's Avatar
Default A6 Bulb change
Is there any links to a DIY bulb change or something?
Old Dec 4, 2007 | 10:47 PM
daroshi's Avatar
Default RE: A6 Bulb change
Assuming you want to change the D2S low beam HID bulb,
Passenger side: remove the flex duct between the rad support & air filter box (Bentley says to remove the air box but I found it wasn't needed, and is a real PITA). Pry over the two metal spring clips holding the plastic cover on the rear of the headlight. Disconnect the insulated wire going into the bulb (pull straight off). Turn the black plastic ring holding the bulb and remove it. Reverse for installation. DO NOT touch the glass on the new bulb at any time as the residue from your fingers will cause it to fail very quickly (like tomorrow!). The drivers side is similar without the air duct. You will have to remove the plastic shroud on the reservoir behind the headlight to gain access.[/align]
Old Dec 5, 2007 | 12:36 PM
topj's Avatar
Thanks alot daroshi, its appreciated
Old Dec 11, 2007 | 11:03 PM
topj's Avatar
yea the bulb i need to change is on the driver side and theres something in the wway.. anyone can help?like wwith pics and stuff
Old Dec 12, 2007 | 01:24 PM
AZAudiA6Q's Avatar
I just changed my bulb. The driver side headlight assembly is the easier of the two to get to. Just remove the retainers and slide it off. You have to be creative. Even pictures won't help you. It's just whether you are good at knowing your angles.
Old Dec 13, 2007 | 12:08 PM
topj's Avatar
if theres even space for it to even slide off, cuz theres something in the way, ill try n get a pic up
Old Dec 26, 2007 | 03:36 PM
topj's Avatar
i think i need a DIY guide
dav78
Dec 21, 2013 09:51 AM
pbrules10
Jul 5, 2010 08:24 PM
audiprotein
Mar 24, 2007 09:49 AM
Ifty
Jan 10, 2006 08:18 PM
stevesim
Oct 28, 2005 05:02 PM
