A6 Central locking problem - DTC 01560
Old Apr 24, 2007 | 03:24 PM
meszrum's Avatar
Default A6 Central locking problem - DTC 01560
Hello.
The car: Audi A6 [C5 2002] 2.5TDI [AYM] EU version.
The problem: I cannot unlock and open passenger door in any way -
there is no possibility to unlock it using the key, the RC and even
from the inside.
I've got huge problem with central locking system in my A6 - the front passenger door are jammed closed and it's impossible to open them. The central locking opens all other doors successfully [via key or RC] and tries to unlock the passenger door also but with no success. If I try to open the door from the inside the lock button lifts up while the handle is pulled but goes down again when the handle is released [without opening the door] Trying to open the door with the outside handle [while the inside handle is pulled open] also doesn't work.
I can't take the inside panel door off since the door is closed.
Enviroment: the car stood 20 days in my garage [I've got knee injury so couldn't even walk].
After I had plugged pc to the car's obd VAG-Com said this:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4B0 962 258 D
Component and/or Version: Zentralverriegelung D34
Software Coding: 06721
Work Shop Code: WSC 02325
2 Faults Found:
01560 - Passenger Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
After I had carefully read the following knowledge base:
http://wiki.ross-tech.com/index.php/01560 ,
I logged the measuring blocks.
Here is the effect:
It's obvious that passenger door can't achieve "Not safe" state and
in effect it's impossible to go from "Locked" to Unlocked" state.
What to do since it's impossible to open the passenger door?
Would You be so kind and tell me if there are 4 independent "Central
Locking Actuator" devices or one device?
If anyone has heard of anything similar or has any suggestions of how to get round this I would greatly appreciate it.
Old Dec 3, 2013 | 08:58 PM
pta's Avatar
pta
Default A6 won't de-safe
How the above problem was solved?
I have exactly same problem and can not open the passenger door.
pooboy66
Jun 16, 2012 01:09 PM
Bulldoug
Apr 28, 2012 05:24 PM
Audi-Tom
Nov 20, 2011 03:17 PM
uaconnection
Apr 18, 2011 12:07 PM
mattius
Jan 21, 2009 02:36 PM
