A6 compression loss
Old Aug 17, 2011 | 09:37 PM
heyduck's Avatar
Default A6 compression loss
After breaking a timing belt due to a bad water pump I couldn't start the engine. I performed a compression test and had almost nothing on 5 out of 6 holes. Knowing I had installed the belt correctly I removed all timing components and began to test compression by rotating cam lobes upward and testing every hole. Same thing. almost no compression. So at this point I'm pretty sure I bent the valves. So after getting over about 3 weeks of bad attitude I pulled the heads and what did I find? nothing! All valves are straight as can be. I had the valves checked at the machine shop and everything is good. Anybody have any ideas as to why I lost compression? My thoughts are I let the engine sit too long and the valve carbon may have solidified. I know the air was escaping past the valves because I poured alcohol down the head at the intake valves and I could blow through the sparkplug hole and watch lots of bubbles come out of the valves.
Old Aug 18, 2011 | 06:53 PM
bob martin's Avatar
You didn't do the compression check properly. Even leaking valves would have given you something.
Sorry,
Bob
Old Aug 18, 2011 | 08:19 PM
rhskcdn's Avatar
Something sounds strange. Can you confirm whether you did a leak down test or a compression test?
steven.whyte
Mar 15, 2012 11:53 AM
taximec
May 18, 2010 01:25 PM
shanefoot
May 5, 2010 10:23 PM
APRII_BlackonBlackA4
Jun 24, 2007 11:07 PM
salmonella
Apr 9, 2007 07:47 PM
