A6 Dies when a/c is turned on
Old Jul 18, 2008 | 04:26 PM
burak's Avatar
Member
Default A6 Dies when a/c is turned on
Hey everyone,
this morning when i was going to pickup my girlfriend i turned on the a/c after a mile the car just died at a red light. I tried to start the car but i got nothing and luckily there was a cop who gave me a push with his cruiser. When i pulled the A6 into a parking lot i made sure the a/c was off and the car started to work fine until i turned the a/c back on. There was some noise coming from under the hood like something was stuck and the car died again. When i got home i was i only had the fans working on the a/c and when i turned the cooling back on the car died. If anyone has any idea please let me know.
Thank you very much
Burak
Old Jul 18, 2008 | 04:59 PM
nothing77's Avatar
Default RE: A6 Dies when a/c is turned on
is your A/C compressor seized?, If may draw locked rotor amperage if it is, this may be more than your alternator can handle, which in turn kills the vehicle. Darn us low paying, dead end job type A/C technicians
Old Jul 18, 2008 | 07:02 PM
kimi's Avatar
what about your CEL did it come on? i wanna rule out poor ignition system ( warn spark plugs and most likely wires) such that when compressor is turn on, more power is desired, which can't be provided by engine. also check your air filter, take a look at your rev counter at idle with AC off, see if it fluctuates, this will rule out leaky vacuums.
Old Jul 18, 2008 | 11:13 PM
nothing77's Avatar
What he said x2, you should def find make certain that things run and are in good working order, If all seems well, then look at that A/C comp., if you can get an amp clamp on the hot wire when it starts, check its amperage
Old Jul 19, 2008 | 02:26 AM
burak's Avatar
Member
Do you guys know where the parts are located under the hood. that would be a great help...
Old Jul 19, 2008 | 07:53 AM
bob martin's Avatar
Burak,
Not to sound mean, but if you don't know how to find an A/C compressor by looking, you don't have the skill set to analyze the problem, much less to fix it. Take it to a professional. You will save time and grief.
Good luck,
Bob
Old Jul 19, 2008 | 11:58 AM
kimi's Avatar
what parts are you refering to. try to lead me so we can help each other out,thats what the forum is all about
Old Jul 19, 2008 | 07:12 PM
burak's Avatar
Member
the part i was looking for was the a/c compressor.
Old Jul 20, 2008 | 03:22 PM
kimi's Avatar
drivers sideright around andabove the oil filter ( the most left of all the components powered by the fan belt)
Old Jul 20, 2008 | 07:54 PM
burak's Avatar
Member
Thanks a lot kimi
audia6s
Apr 9, 2008 05:11 PM
AudiAngel
Aug 11, 2006 07:41 AM
Cameron
May 11, 2006 03:48 AM
Panzer Kommander
May 7, 2005 05:24 AM
