A6 electrical problem I think? PLEASE HELP
Old Aug 5, 2008 | 09:25 PM
wrenegade's Avatar
Default A6 electrical problem I think? PLEASE HELP
Hi,
I just brought an 98 A6 about a week ago. The car runs great but I just began noticing a few problems. Sometimes when I start the car my headlights/blinkers don't work at all and I have to stop the car and restart it again and they work fine.
Secondly, my rear windows will do not work from either the front or the back. And when I'm driving I can smell something burning. It isn't a strong smell but it is noticeable, maybe burning rubber smell?
Anyone else had these sorts of problems and if so what did you do? Should I stop driving it until I can get it serviced or am I just overreacting. Do you think its a big electrical problem?
PLEASE HELP! I would greatly appreciate it.
Old Aug 5, 2008 | 11:42 PM
formulagigi's Avatar
First problem, I had the same issue with my 96 2.8 and there was a recall for that problem. Forgot what it was... check out the recall on line.
Window issue: could be regulator/plastic guide.... known issue. Plastic giude is prone to breaking.
Old Aug 6, 2008 | 12:04 AM
Frank D's Avatar
Originally Posted by wrenegade
Hi,
Call me at 1-978-761-5582, I an an Audi technician and I can tell you whats wrong with your car. 1-978-761-5582 Frank Dota
Old Aug 6, 2008 | 09:29 AM
Ligist's Avatar
is ur car manual? if so, is it ur first time driving one? the burning smell could be u slightly burning ur clutch, if not, the burning rubber smell is a tell sign of an electrical problem yes, seeing as frank is a tech. i would give him a call for further help
Old Aug 7, 2008 | 08:29 PM
audi_sf's Avatar
Hey was this ever solved? What ended up being the problem?
Old Sep 24, 2009 | 08:03 AM
Frank D's Avatar
change the electrical portion of the ignition switch and look for a crack in old switch.
Old Sep 24, 2009 | 10:35 AM
NH_USA's Avatar
Frank 978 sugests your in the Lowell MA area - where are you located?
Old Sep 24, 2009 | 12:12 PM
Jeffla's Avatar
Ignition switch (as mentioned above)
window regulator/motor
cam seals (burning oil can smell like rubber)
DurTTy
Oct 5, 2007 03:41 PM
steelcitysfinest69
Jul 24, 2007 01:42 PM
tbr76
Jan 13, 2007 02:14 PM
miabhai_freaked
Feb 22, 2006 11:12 PM
