A6 headlight problem
Old Feb 2, 2008 | 12:00 PM
vivekgupta's Avatar
Default A6 headlight problem
I have a 2004 A6 Quattro. Recently the passenger side headlight has lost its intensity. The bulb glows but it projects a pinkish glow. I've been told that the problem could be the ballast resistor. Can anyone advise whether this is something I can fix myself or do I need to take it to a dealer. Thanks.
Old Feb 2, 2008 | 04:34 PM
i3uddha's Avatar
Site Moderator/Ninja
Default RE: A6 headlight problem
welcome to the forums...
hopefully they can give u some more info here in the A6 section..
try using search function as well "ballast resistor"
and see if that helps out at all..
good luck
Old Feb 2, 2008 | 06:43 PM
Nocturnal_A62.7's Avatar
Ballast problem sounds right. If you car is still under warranty, won't hurt a quick visit to the dealer.
Welcome, to the forums.
- Rashtriya_Swayamsevak _Sangh
Old Feb 2, 2008 | 09:00 PM
dankhound's Avatar
You can also try swaping the bulbs from side to side to see if the problem follows the bulb.
a. debarros
Jun 24, 2011 11:57 PM
bpguitarbiker
Aug 20, 2008 11:20 PM
paparose_12
Oct 29, 2007 10:00 PM
DieHardAudiA4
Oct 13, 2007 11:14 PM
The Somps
Feb 18, 2007 08:10 PM
