Low beam headlight flashing....?
Old Mar 8, 2008 | 11:41 AM
Blue01TT's Avatar
Default Low beam headlight flashing....?
I changed bulbs in my car yesterday and after i got the new ones in my pass. low beam started blinking almost like a turn signal. it seemed to consistent for a bad connection because the flashes were on like 3 second intervals. then i put my stock ones back in and it does the same thing but only on the pass. side still, the driver side worked well with both?
Old Mar 8, 2008 | 12:00 PM
achTTung's Avatar
Default RE: Low beam headlight flashing....?
check all your wiring again, it kinda sounds like a ballast on its way out, but the ballast acting up may just be from something that got moved/loosened.
Old Mar 8, 2008 | 01:52 PM
Blue01TT's Avatar
well i unhooked the bulb hooked it back up and unhooked the battery to reset the ecu and now its working fine. I hope this isn't a sign for future eletrical problems [sm=boohoo.gif]
Mr.Robertson
Oct 28, 2013 12:32 PM
exmerc
Aug 13, 2008 04:21 PM
Shaudi
Jul 29, 2008 12:24 PM
rifishman
Aug 5, 2005 10:38 AM
streethawk
Jan 2, 2005 08:47 AM
