A6 - Resetting computer to pass inspection ???
Old Mar 6, 2008 | 11:21 AM
hxgaser's Avatar
Default RE: A6 - Resetting computer to pass inspection ???
Driverside main catalytic converter is throwing that code. It should not be oxygen sensors.
FYI, federal emissions warranty covers catalytic converters up to 8 years or 80,000 miles. If you car is below that range, take it back to Audi and they will replace it for free. What they will do is reset the code, and see if your readiness code sets or not. If it does not set, then they will replace the cat for free. I had the exact thing happened to mine, and my mileage was at 79,850.
Good thing is that your cat is the main cat, not the pre-cat. Main cat is easier to access than the pre-cat. So even if your mileage exceeds the warranty limit, replacement is pretty simple.
Old Mar 6, 2008 | 11:23 AM
hxgaser's Avatar
Oh, forgot to answer the second part of your question... If cat is bad, it can affect the performance. Normally, even if it is throwing the code, it has sufficient flow. But if it really gets plugged, then it will cause problems with running.
Old Dec 21, 2017 | 04:17 PM
tibor_g_balogh's Avatar
Originally Posted by hxgaser
It may or may not work. In California, smog machine not only checks for any CELs, but it also checks for a readiness code. When the CELs are reset, ECU cycles through certain criteria, such as time it has been driven, information fromall emission related equipment, and duration and etc. Then it sets a readiness code once everything checks out. If the readiness code is not set, then you can't pass smog check.
The readiness code may set after you reset the CELs, but you need to verify with a code reader that has readiness checking capability.
Hi everyone, new A6 owner/mechanic here, can someone tell me what ODB2 reader to buy (Amazon.com) to be able to see my car's ready-state for smog check purposes in California.
millenia
Dec 23, 2019 11:47 AM
audiup
Jan 6, 2011 12:25 PM
cmarin
Jan 21, 2010 05:50 PM
Dudek12
Jun 2, 2006 11:07 AM
BrokenTT180
Jan 24, 2006 11:31 PM
