A6 Tail Light
Old Jan 26, 2007 | 03:09 PM
bigaudifan's Avatar
Default A6 Tail Light
2001 A6
4 out of my tail lightsare not working. any similar case??
Old Jan 26, 2007 | 05:20 PM
WaggsA6's Avatar
Default RE: A6 Tail Light
Have you checked the fuses or to see if they are burned out? We can't give you to many answers to a question that vague. Which lights are out? Do they stay out when on the brakes?
Old Jan 26, 2007 | 06:38 PM
Boston Driver's Avatar
If you are talking about the center stop light (3rd brake light), yes, it is common for those to go out. I replaced 5 of the 10 when I picked up my car last year from the used dealer in Chicago. They run a couple of bucks each from the dealer. All you need to do is to reach up from inside thetrunk, remove the little plastic panel that is right under the light, then remove the light "bar" from the retainer clip. Then use a heavy item (like a computer bag) to depress the brake light, and make note of which bulbs need to be replaced. Good luck!
pbrules10
Aug 2, 2011 01:22 AM
MagicHobo
Nov 14, 2008 01:37 AM
tsk
Apr 27, 2008 04:56 PM
audi ace
Jul 22, 2005 01:53 AM
