A6 Tail Light
If you are talking about the center stop light (3rd brake light), yes, it is common for those to go out. I replaced 5 of the 10 when I picked up my car last year from the used dealer in Chicago. They run a couple of bucks each from the dealer. All you need to do is to reach up from inside thetrunk, remove the little plastic panel that is right under the light, then remove the light "bar" from the retainer clip. Then use a heavy item (like a computer bag) to depress the brake light, and make note of which bulbs need to be replaced. Good luck!
crazybk187
Aug 5, 2013 04:29 PM
MagicHobo
Nov 14, 2008 01:37 AM
