abs light on
Old Jul 11, 2005 | 08:02 PM
mcmro's Avatar
Default abs light on
hello ! every one . when I drive over a hole in on the road and the shock is harder the ABS light comes on .and stays untill I stop ,turn engine off .when I start the engine and only after I get the car moving the light will go off . Any opinions about this.? thanks anyway !
Old Jul 11, 2005 | 08:04 PM
mcmro's Avatar
Default RE: abs light on
sorry I forgot to specify the car AuDI A6 1997 18 T
Old Jul 12, 2005 | 01:26 PM
dan908's Avatar
Clean your ABS sensors
Mine used to do that until I burnt out the abs light bulb. The ABS wheel sensors probably never get cleaned and they are a magnet so they probably got so much crap on them they can't read the wheels. Mine burned out at 130K because of it. 170 a piece so a little prevention saves you a lot of money.
It is not bad if the ABS bulb comes on, you still have brakes.
Cleaning the sensors, pretty easy with the 97. Ahead of the rear drums and behind the fronts is a cylinder (you will only see the plastic cap with a wire) about 1/2 inch (10 mm) in diameter. Find something that can get a good grip around the plastic cap (but not damage it) and it should just slide out. Depending on your mileage, it may be really stuck so you might need to twist a little but they just slide in and out. Clean it off, and it is recommended that you also put a tiny bit of oil on the sensor and rub it in to make it slide easier (I agree). If you already cooked the sensor, this won't help and you can kiss 170$ X # of sensors gone (your computer will tell you how many misread).
Old Jul 14, 2005 | 05:32 PM
mcmro's Avatar
thanks for the advice.I will try that
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
