ABS problems after control arm install?
Old Jul 8, 2009 | 10:58 PM
cassidyjr's Avatar
Default ABS problems after control arm install?
I replaced my control arms over the weekend, took it monday to get an alignment and everything seemed good except for when braking the abs comes on when coming to a complete stop. It seems to do it right between 15-20 mph each time, and if the car is driven for any extended amount of time, the ABS light comes on and the issue stops. Im assuming when the light comes on, its making the ABS turn off.
after searching around here and audiworld, I found a few people said they had the same problem, but never really found much of an answer.
I was thinking maybe it was the ABS module, but it seems like most people who have the malfunction have a permanent ABS/Brake light, which I havent gotten the brake light, and ABS only comes on somtimes.
Im thinking maybe wheels speed sensor? any one else ever have this issue?
Old Jul 9, 2009 | 12:21 AM
chefro's Avatar
It could be.
You can actually double check if it was inserted back properly seated.
When I pulled mine out, I noticed a bunch of old crusted dielectric "grease". You can spray some QD Electronic Cleaner, clean that old gunk out and then slap back on some fresh dielectric grease.
Old Jul 9, 2009 | 01:03 PM
Midniteoyl's Avatar
Wheel sensor issue, most likely. There's a gap it must be set too.. cant remember what that is but its very close.
Old Jul 10, 2009 | 02:05 AM
cassidyjr's Avatar
anyone by chance know what the gaps are supposed to be set to? I plan on doing this saturday, guess I should figure out what im doing before I go taking everything apart lol
ex56TT
Sep 23, 2013 09:52 AM
mckeenr
Oct 31, 2010 11:45 AM
A6in08
Apr 30, 2008 09:31 AM
k5gixxer
May 19, 2007 11:58 AM
haveaseat
Apr 2, 2007 10:07 PM
