Acceleration Hesitation/Jerking
Old Mar 9, 2018 | 05:24 PM
  #21
araba's Avatar
I had the same issue. Replacing coils did not solve the problem, but improved the jerking at least. But, still the acceleration is delayed and jerking is present occasionally. I got the error codes EVAP small leak and camshaft sensor A (bank 2) malfunction...
Old Jun 28, 2019 | 10:53 PM
  #22
Elizabeth Nichole's Avatar
Originally Posted by Shems Dervishi
I have a A4 2.0T and having issue jerking when accelerating, also the check engine light is flashing when is jerking. anyone with same problem and know what to look for to fix the issue.
thanks
Bad/ fouled Spark plugs, spark plug wires, throttle position sensor, or throttle body alignment issue.
Old Aug 12, 2019 | 10:55 AM
  #23
Janae Powell's Avatar
Do you have OBD? It should tell you what's the problem, so no need to guess. A cheap one can be ordered from Amazon, apps don't cost much as well, some of them are even free, like this one https://play.google.com/store/apps/d....motordata.obd, I've been using it for a while and so far I'm satisfied with it.
Old Oct 13, 2019 | 05:28 AM
  #24
marando's Avatar
Banned
Sounds like you have a vacuum leak some where. Locate and make sure there are no loose tubes or cracked ones, starting from the intake all the way to the turbos and to the intercooler and then back up to the throttle body.
Old Apr 13, 2021 | 02:27 PM
  #25
Jared206's Avatar
Default 2007 audi A4 2.0t
Same issue , cold start and drive is great. Car warms up, if I baby the gas it's perfect . Second I want to go faster it spudders.sometimes back fire.. motor light flashes then off. Codes read cylinder 4 misfire, cylinder 3 misfire, multiple misfire. Replaced coil packs, spark plugs , air filter clean. Thinking fuel injectors? Or what.... sensor?? Hey thanks for any info at this point.
alvocado
Jul 12, 2021 11:49 AM
av_navy20160606
Aug 10, 2017 09:14 PM
newhandle
Jul 17, 2012 11:56 AM
compman723
Jan 10, 2012 12:57 PM
joenelson7687
Apr 26, 2010 06:04 PM
