Access to TCM wiring plug/socket pins
Old Jan 4, 2010 | 12:52 PM
audi4's Avatar
Question Hello, could you tell where can I buy those wires?
my local dealer said they dont sell replacement wires.
I got issue with my connector aswell
Originally Posted by porschefan
I went to my local Audi dealership and they showed me the replacement sockets.
Basically they sell a wire about 12" with a female socket on each end ($15) i bought 5 but he only charged me $6 each because i had to wait a while for them to track them down.
When the female socket block is removed is actually splits into 2 halves horizontally allowing slightly easier access to the sockets. I noted one of the my wires had come completely loose due to the corrosion.
I tried multiple small screwdriver attempts to release the pins, but in the end it was some gentle persuasion and a spot of brute force to remove them. I only actually had 2 sockets that were corroded so i cut the wire into about 1" lenghts from each end. Soldered the original wire to the new socket wire and replaced.
Voila my TCM code has gone Next thing is to get the throttle body sorted and i should be back to normal.
Old Jan 4, 2010 | 06:59 PM
snoopra's Avatar
Basically they sell a wire about 12" with a female socket on each end ($15) i bought 5 but he only charged me $6 each because i had to wait a while for them to track them down............................l.
Do you have the part #'s?
Old Jan 4, 2010 | 11:26 PM
audi4's Avatar
I was not able to find part # for the pin. Neither dealer said i can buy them?
Can someone help where can I get few of those?
Old Jan 5, 2010 | 09:29 AM
porschefan's Avatar
I'm not sure of the part no. i described the part and someone from the service dept. came in with what i described.
I'll see if i can find the original receipt, it should have the part no. on it.
Old Jan 5, 2010 | 09:45 AM
porschefan's Avatar
OK found it:
Part No. is 000-979-133 it's called a 'Wire set'
hope that helps
Old Nov 2, 2011 | 11:46 AM
AudiSouth's Avatar
Default TCM Wiring plug/sockets
My TCM was soaked and I am replacing. When doing so I noticed the female sockets that the TCM plugs into were coroded and a few wires had actually broken loose. Has anyone tried to replace the entire housing with the female sockets and splice the wires back together? Thanks
tanseysteve
Apr 30, 2014 04:51 PM
vtraudt
Jan 2, 2013 10:38 AM
phatboyfromla
Dec 6, 2010 08:38 AM
2ndmoto
Nov 17, 2010 11:37 PM
nitro_rider2001
Dec 14, 2006 03:52 AM
