Adding A/C Refrigerant To My 95 A6?
Old Aug 24, 2011 | 09:04 AM
1995_A6_Driver's Avatar
Default Adding A/C Refrigerant To My 95 A6?
I found a low side port under a switch near the top of the A/C run but it appears to be a fitting that doesnt connect to the ones on the bottles sold in stores. Is there a fitting sold to adapt these bottle fittings and do you know if the refrigerant wouldve been converted over from R12 to R134 refrigerant? Thanks friends.
Old Aug 24, 2011 | 12:42 PM
ManyAudis's Avatar
The 95 A6 refrigerant is not supposed to be topped off through the low side port like many other cars. You are supposed to evacuate it with a vacuum pump and refill. Having said that, I did refill my daughter's '95 Audi 90 Sport Quattro a few times using a refrigerant manifold I purchased at Harbor Freight. That was some years ago so I do not remember the details. I think I may have filled through the high side port when the car was off.
Old Aug 25, 2011 | 08:01 AM
Default I found the port
It needs an adaptor that screws on to fill. Its not the pop on type of adaptor that refrigerant cans come with.
benpa
Jul 23, 2013 10:05 PM
AK_47
Sep 8, 2009 11:26 PM
blufflion
Jul 6, 2008 06:42 AM
onepoint8tee
Sep 12, 2007 02:41 PM
toda
May 14, 2007 08:31 PM
