I hate that my car does not have memory seats. It is the only car in the last 10years of mine not to have them. It drives me nuts when my partner drives the car and then I spend the next two days trying to get it back to where I like it. I see that my door pockets have the wires for the memory switches, is that all I need is the switch, or are there other parts in the seat that I don't have.
Thanks,
Jeff
Thanks,
Jeff
RE: adding seat memory
Removing and installing control unit for memory seat
Note![/align]
Control unit for memory is located beneath driver's seat.
Remove seat →Chapter.
Remove inner seat side trim →Chapter.
Unplug connectors -4- and -5-.
Unscrew bolt -2-, tightening torque 1.5 Nm.
Use screwdriver to press fastener -3- in direction of arrow.
Detach control unit for memory -1-.
no seat ecu no memory
[IMG]local://upfiles/12092/46CCB01C87644F4C9AC74E6016B74DAB.jpg[/IMG]
Note![/align]
Ok, so it looks like I will need a controller as well. Will have to look at my seat to see if I have the correct wiring harnesses as well.
Thanks,
Jeff
Thanks,
Jeff
