again, EVAP System: Large Leak Detected
Old Apr 12, 2010 | 10:30 PM
vrso2's Avatar
Default again, EVAP System: Large Leak Detected
Hmmm, that sux.
I changed N80 Valve, gas cap but still same code:
16839 - EVAP System: Large Leak Detected P0455 - 35-00 - -
Worst thing is, i can feel now gas odor inside the car while driving.
any suggestion ?
Old Apr 13, 2010 | 11:47 PM
auditech79's Avatar
If you can smell it in your car i bet you need a gas tank. There are several nipples on the top of the tank that can break off and cause a large evap leak. It usually gets worse over time, read my sticky. I believe there is a recall for it now, ask the dealer if your car applies, i think it does.
Old Apr 15, 2010 | 09:53 PM
vrso2's Avatar
LOL, COOL, ill call them 2mrow. How difficult is fix the problem ?
Old Apr 15, 2010 | 09:57 PM
vrso2's Avatar
hmmm, but, looks like there is no recall for it:
http://www.automotive.com/1999/12/au...lls/index.html
Old Apr 15, 2010 | 10:01 PM
vrso2's Avatar
hmmm, this is happened to me too many times :
MAR 22, 1999 | Recall ID# 59120
.....BACK PRESSURE TO CAUSE FUEL TO BE EJECTED AFTER A COMPLETE FILL-UP WHEN THE FUEL PUMP NOZZLE IS REMOVED FROM THE FILLER NECK......
Old Apr 15, 2010 | 11:01 PM
auditech79's Avatar
Well that recall isn't what im talking about. If you notice you smell the gas more after you just fill it or notice a small puddle of gas under the car after filling it you most likely need an entire gas tank.......which would really suck. To diagnose it you need to remove the ENTIRE rear end from the car just to get the gas tank down.
jafferman
May 6, 2013 06:32 PM
eazy211187
Dec 30, 2012 04:53 PM
icepl
Jul 4, 2009 08:42 PM
kirklandb
Nov 13, 2008 09:25 PM
Jagermeister
May 3, 2005 01:11 AM
