Air Con problem - advice needed!!
Hello you lovely people.....
I have a problem regarding the Air Con on my 1995 A6.
My AC has quit....
When i hit the button on the console for AC, the symbol lights up and the secondary cooling/condenser fan starts up ok.....
But, there is no drop in rpm or no compressor sound... which was all ok before, plus theres no cooling from the AC anymore.
I have identified the clutch power supply and when the button is pressed, there is no power supplied to the clutch...
I have even identified the relay.... it seems ok...
Is there some black magic computer wizardry involved anywhere that might be responsible or are there any obvious commom failure points i need to look for.
Any help would be appreciated.
Cheers.
My AC has quit....
Cheers.
You have climate control diagnostics built into your car, use them for answers or hints to your problem.
http://www.audiworld.com/tech/int5.shtml
