airbag light?
Old Dec 8, 2008 | 02:37 PM
madman1234509's Avatar
Default airbag light?
i got up this morning and went out and started up my car to let it warm up for 10 minutes like i do every morning before i go to school (if i dont let the car warm for a few minutes up the check engine light will come on), i got in the car to leave and realized the airbag light was on. Ive never had this happen before. And this was the first morning that its literally been below 0 degrees outside since ive owned the car. Is there anything i should look for or a fuse to check or something?
Old Dec 9, 2008 | 12:50 PM
NH_USA's Avatar
You need to run a VAGCom to see what is going on.. The airbag light means it is not being armed for some reason.
I would be concerned that the CEL comes on when you drive without warming up a little.
Old Dec 10, 2008 | 09:50 PM
the codes ive gotten from the cel is for the secondary air injection being too low on one side. and its been looked at and the cheap plastic connectors on the valves behind the motor seem to be worn. but why would the airbag light just randomly be on now. its just weird. i thought the cold weather might have screwed it up. but it hasnt come off yet like my check engine light does.
Old Dec 15, 2008 | 12:13 PM
NH_USA's Avatar
No clue on the air bag -- I had an airbag light on an 89 QT200 that would take a few minutes to go out ( I was told it was because the sensor was going bad and it was taking a long time to arm itself.) Finally it would not go out so I just removed the bulb...
The secondary air injection is a common problem - 90% of the time it is bad vacuum lines requiring a few minutes and a couple $ worth of parts to fix
Old Dec 15, 2008 | 12:28 PM
auditech79's Avatar
Airbag lights can be triggered by back seat passenger's, the wiring goes directly under the front seats, so when people ride in back they can kick the wiring. It happens all the time in my A4. There is also a TSB to repair wiring in the back of the driver seat for an airbag related concern. It could also be a bad airbag too.
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
