airbag module replacement
Old Dec 26, 2006 | 11:38 PM
aud99's Avatar
Default airbag module replacement
can you replace a airbag control module with an old one.
i had a dtc65535 code come up and my light is one thanks.
and also wat would the procedure be for reprogramming the othe module.
Old Dec 27, 2006 | 06:50 AM
twinturbomew's Avatar
Default RE: airbag module replacement
no you can not replace trhe module with a older one. In some cases the model #'s are same from year to year this is your best chance
Old Dec 27, 2006 | 08:06 AM
techbod's Avatar
you need the correct part you cant just stick any module in there and you cant program them they are factory set, its all down to how many airbags you have in the cabin early models only had a couple newer ones have many, if you can match the module to the same amount of airbags in each car then it might work but ensure the battery ground is off and you have any audio codes needed, then turn the ignition key on and reconnect the battery that way your out of harms way if the airbags blow out
pologoped2
Jul 28, 2013 05:47 PM
vtraudt
Jul 15, 2013 08:21 AM
ed1380
Sep 14, 2011 07:10 PM
Niclipse
Apr 11, 2011 05:29 AM
225GUY
Mar 16, 2010 11:46 AM
