Any fix for this?
Old Dec 5, 2008 | 03:31 PM
trader220's Avatar
Default Any fix for this?
Little bit of haze on the headlights. What are you guys doing to clean this problem up short of replacing the units?
Old Dec 5, 2008 | 05:12 PM
the G man's Avatar
Try this 3m product, it works pretty good.
http://www.shop3m.com/60455033872.ht...KU=60430050413
Old Dec 5, 2008 | 05:20 PM
trader220's Avatar
Thanks
Old Dec 5, 2008 | 06:54 PM
oc_audica's Avatar
there is a standard process that consists of wet sanding and polishing...
Old Dec 6, 2008 | 01:32 PM
Firefighter6484's Avatar
I just recently restored mine. I started out ry sanding with 400 and 600grit, then wet sanded 800 to 2500 grit until almost all scratches where out. I then took a mothers buffing ball, and some plastic cleaner polisher to them.
Took me about 2 hours on each light, and they look great. they do not look brand new, but they are clear, and almost no scratches in them. I was very happy.
Old Dec 6, 2008 | 02:36 PM
alexfunari's Avatar
brasso baby, takes 30 seconds, don't believe me? look it up!
Old Dec 7, 2008 | 12:40 AM
ImTheDevil's Avatar
You can use a mild rubbing compound and a high-speed buffer, and it'll clear things up nicely. Be careful with the speed though - go too fast and the heat will burn the compound into the headlights forever.
