Arg! Water pump killed my car!
Ok , has anybody had this happen? Our water pump pulley tried to fall off and dumped all its fluids onto the ground so we had it towed home . the water pump pulley made the timing belt super loose and the cam alignment is off by about two teeth , using the cam bar and crank lock pin .
I was going to replace all the parts re align everything correctly and hand rotate the engine to see if anything is hitting then check the compression . would that be the correct thing to do ? great time to crap out on us ! Merry Christmas
grrrr
Thanks Bob , well i did all that and the engine seems to have zero compression i can turn it over with ease to easy in fact ,so i guess i will be doing a comp test next . ( getting a sinking feeling in the gut that it has bent valves )
doing the heads isn't too bad. You do need a special tool for the head bolts and since they are torque to yield bolts they need to be replaced out taken out. There are quite a few threads out there about getting the heads off, just google it
Have fun.
A used motor generally, in my experience, works out a bit cheaper than a rebuild, but with a rebuild you know what you have. If you are planning on selling the car, go used. If you need the car quickly, go used. Otherwise, rebuild.
Bob
Bob
