Back into the brotherhood :D
Old Oct 4, 2010 | 08:24 AM
01A642's Avatar
Default Back into the brotherhood :D
Hi guys,
I just traded my Corvette for a 2001 Audi A6 4.2 on Saturday. It's been quite a while since I've owned an Audi (I had an 5000 and 4000S in the 90's). The only issues with it are the center LCD and the driver's side driving/fog light is out. I may give my soldering skills a test and try to fix the LCD but how in the heck do you get that fog light out to change it?
Thanks,
Old Oct 4, 2010 | 10:05 AM
02A6Beau's Avatar
the grille around the fog light pops right off. pull it straight out. then a couple of screws and Bob's your uncle (don't know what that means but it seems to fit here based on how I have heard other people use it). Should be an H3 bulb.
Old Oct 4, 2010 | 12:35 PM
01A642's Avatar
Too easy, thanks!
Old Oct 4, 2010 | 01:56 PM
bob martin's Avatar
You need to pull on the outside edge of the grill. It does not quite pull straight out, or, at least, it isn't designed to!
Uncle Bob
Old Oct 4, 2010 | 03:40 PM
hxgaser's Avatar
Center LCD is fading? or completely out? Fading is soldering issue. It is bit more complicated than straight soldering. Anyways, if is completely off, then a simple press on a button below the wiper stalk may resolve your issue.
Old Oct 5, 2010 | 07:11 AM
01A642's Avatar
It's not completely out, just unreadable, most of the lines are out so I can't tell what's supposed to be displayed. I googled it last night...the replacement is probably above my basic soldering skills.
Old Oct 6, 2010 | 12:32 PM
Khardysius's Avatar
And you found the right engine code too! (AWN)
Welcome back!
11audi
Dec 24, 2011 02:37 PM
nokrusko
Dec 7, 2011 09:40 AM
dubman6
Aug 21, 2010 12:43 PM
juice88
May 17, 2007 05:21 PM
fresh1
Sep 8, 2004 11:09 AM
