bad smell when using defrost on windshiled
Old Mar 26, 2009 | 02:05 PM
copper07's Avatar
Default bad smell when using defrost on windshiled
When i turn the defrost on the windshield there is at times a bad smell, like burning rubber or oil. It only happens once and a while. what can I check to see what is causing the smell. It worries me.
Old Mar 26, 2009 | 06:24 PM
oc_audica's Avatar
have you changed your cabin air filter?
Old Mar 26, 2009 | 10:27 PM
Coors's Avatar
Is there any fog or condensation on the windshield. Your heater core could be leaking.
Old Oct 25, 2009 | 07:17 AM
davetremblett's Avatar
Default heater core
i have the same problem.
how did you make out?
Old Oct 25, 2009 | 11:12 AM
bob martin's Avatar
The smell of burning oil is probably burning oil. A leaky valve cover gasket, can adjuster seal or cam seal will allow oil to drip on the exhaust manifold causing the smell. You only get it once in a while because it is a small leak and you get it when you turn on the defrost due to the volume of air being moved and the fact that the air is being moved up by your nose instead of at your feet.
But, make sure to change that cabin filter, as well!
Bob
frankegd
Feb 11, 2013 06:45 PM
bin shams
Apr 9, 2012 03:45 PM
little_town_audi_owner
Feb 14, 2009 12:41 PM
millenia
Jul 11, 2007 10:26 PM
