Battery compartment full of water?Help SOS
Old Nov 27, 2006 | 12:10 AM
fhf3723's Avatar
Default Battery compartment full of water?Help SOS
Any one know where the drain is for the Battery compartment for an 99 A6? Full of water then it leaks like a sieve inside the car. the whole foward plenum area is full of water? Help! thanks
Old Nov 27, 2006 | 12:48 AM
SouthboroAudiGuy's Avatar
Default RE: Battery compartment full of water?Help SOS
There are two drains that tend to get clogged with debris (leaves/pine needles/etc.). Remove the battery. Underneath the plate that supports the battery is one of the drains. The other is to the right of it when looking from the front (towards the driver's side).
Once you've cleaned them out (pressurized air may help), check the area twice a year to make sure it's free of debris).
Good luck. Stay on this -- that water flowing into your passenger area can trash your electronics.
sawalski
Jun 18, 2012 02:07 PM
shmltn
Sep 6, 2011 11:59 AM
ljride
Jun 23, 2008 12:36 AM
schmooser
Jan 7, 2007 03:25 PM
HansBlix
Nov 24, 2006 05:29 PM
