Water Sounds From Front Engine Compartment
Old Oct 12, 2006 | 09:14 PM
HansBlix's Avatar
Default Water Sounds From Front Engine Compartment
After the car spent a night outside during a rainstorm, I've been hearing water sloshing back and forth somewhere in the direction of front engine compartment every time I make a sharp left or right turn. (AC is "urinating" normally) I removed a couple "dirt panels" in the engine compartment and got some of the water and gunk out from where I thought it would be, but the sounds persist. Will the rainwater (presuming its water) just drain itself out over the course of a few days, or do I need to take measures to really find all of it under there?
I will greatly appreciate any advice!
Old Oct 14, 2006 | 01:10 PM
dankhound's Avatar
Default RE: Water Sounds From Front Engine Compartment
You probably have a plugged up drain somewhere. Itll probably keep sloshing untill the drain is unplugged. Check near the cowl area.
Old Oct 14, 2006 | 08:01 PM
HansBlix's Avatar
Thanks, but it seemed to have cleared itself up in 24 hours, glad that's over.
Old Oct 15, 2006 | 02:11 AM
AWDaholic's Avatar
Senior Administrator
At least, if it comes back, you know where to start looking...
Old Oct 26, 2006 | 03:28 AM
AUDIA8's Avatar
There are drains above the trans for the plenum under the hood where all the electronics sit. The car will need to be on a lift to access them. The drains are on the left & right of the trans if u are looking staright up at it. Had the same problem with mine. Make sure to get those drains cleared as soon as possible. If those elctronics get wet it WILL SNOWBALL on you & cost$$$$$$.
Old Nov 24, 2006 | 05:29 PM
FastrNU's Avatar
That sloshing sound could also have been water accumulated in the center of the car. Remove the rear center A/C vents and take a peek. Sometimes the water will accumulate there and I have to vacuum it out. In extreme cases (you know, like going to a car wash) water can pour out of those rear vents.
shmltn
Sep 6, 2011 11:59 AM
6speedtt
Aug 11, 2008 10:56 AM
JerseyS4
Jul 9, 2008 01:08 PM
fhf3723
Nov 27, 2006 12:48 AM
bjd96A4
Sep 13, 2006 01:34 AM
