Blinker problems
Old Apr 30, 2006 | 03:39 AM
ffkk's Avatar
Default Blinker problems
First of all hello and thanks for looking.
I have a problem with my blinkers it seems and its kind of a wierd one. I searched the forums and cound't find anything like my problem. It started with the right blinker by blinking fast and all the blinker lights worked except the front right one. Then couple hours later the left one started doing the same thing and now both front blinkers dont work and blinks fast. I replaced the bulbs and that didn't work. I then replaced the emergency flasher relay thingy and that didn't work. I checked the fuses and they were all ok.
Now the thing is, when I turn my headlights on, the left one turns on super bright (both elements are turned on) and the right blinker turns on (one element). Unlocking and locking the doors all the blinker lights turn on except the front two. Doing the emergency lights all the normal blinker lights turn on except the front two.
Any thoughts to what could be wrong?
-fk
Old Apr 30, 2006 | 11:05 AM
europabluea6's Avatar
Default RE: Blinker problems
I think you will find it is the carrier for the indicator lamp that is the problem in both cases. It is a bayonet fitment with 2/3 contacts (Euro or US Spec), over time these become oxidised. If you remove the holder and clean up the contacts with 600 grade emery it should solve your problem I think.
Regards
Europabluea6
Old Apr 30, 2006 | 12:18 PM
dankhound's Avatar
Also make sure the part of the headlight that the socket goes into isnt melted. That can happen sometimes.
Old Apr 30, 2006 | 12:47 PM
techbod's Avatar
the left one turns on super bright this means you have a bad ground clean all connectors
irunktm
Oct 23, 2012 11:29 AM
a6in
Oct 25, 2011 03:17 PM
zacmck90
Apr 23, 2011 08:51 PM
seanmaldo
Feb 14, 2010 08:31 AM
duburban
Jan 18, 2007 06:31 PM
