Bolt Freewheeling in MAF housing
Hi Guys
I'm having some issues with a MAF sensor, i'm swapping 2 around including a so called 'new' one that has been throwing up 'Engine too rich' codes. My original one seems OK after i managed to get some tamper torx to remove the hot wire to clean it properly.
Unfortunately i think i may have overtightened one of the bolts as now when i try and remove it, it's just freewheeling and not coming out. I don't think its broken, more likely the thread housing is loose inside the plastic box cover.
Anyone had this problem before? know a way to fix it?
Cheers
Cheers
Well, i fixed it, but no amount of levering was going to help.
In the end i clamped the end of the bolt with Vice Grips wiggled and pulled, the whole bolt came out fo the plastic housing with Brass thread attached.
I then removed the brass thread from the screw and epoxied it back into the plastic, seems to work fine
sm937
Jan 21, 2013 10:19 AM
Cubanator
Nov 13, 2012 04:26 PM
coolwater
Jul 27, 2010 11:30 AM
