Brake Light problem
Old Aug 28, 2009 | 03:41 PM
Tripin's Avatar
Default Brake Light problem
My break lights arn't turning off. I havn't done anything to my car just all the sudden this morning I realized they were staying on..I mean cars off, locked and everything but they just stay on. I lifted up on the pedal but it's still on. Is there a solution for this?
Old Aug 28, 2009 | 05:44 PM
Jackmup's Avatar
most likely the switch on the pedal is bad. It is behind the top of the pedal probably cracked or has dirt stuck in it. It is a simple push button try to pop it back out and lube it up with vasiline to get it working then order a new one.
Old Aug 28, 2009 | 09:21 PM
renaissance_warrior's Avatar
Stuck switch. Spray some WD40 and order a new one.
Old Apr 12, 2013 | 10:15 PM
daniellewis161's Avatar
thanks guys mine is doing the same thing! I will try the switch! ill repost if I find something different for some reason!
luciddream42186
Jan 25, 2012 08:13 PM
ziggy64
Mar 10, 2011 09:13 AM
peterbr1717
Aug 13, 2010 03:28 PM
jonsaudi
Nov 21, 2007 04:18 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
