Brake Pad Warning Light
Old Dec 3, 2007 | 10:17 AM
jerrod22's Avatar
Default Brake Pad Warning Light
So my brake pad warning light came on the other day. Car has 44K miles. Is this something that I need to address right away or do I have any time on my side??? How much for replacement pads all around?????
Thanks!
Old Dec 3, 2007 | 01:25 PM
DjDiddles's Avatar
Default RE: Brake Pad Warning Light
Most likely needs to be done farely soon!! Look at the pad and see how much is left! It's pretty thin do it soon so you don't ruin your rotor as well!! Pads will probably run you $40-$80.00.
Old Dec 3, 2007 | 03:34 PM
Retard Riot 686's Avatar
Yes do it relativly soon. Brakes saves Lives hahaa but yeah look from 40-80 bucks like Dj said ull want a goood set on there. Easy DIY if ur able too
Old Dec 3, 2007 | 04:17 PM
paaudia6's Avatar
Member
i would'nt recommend any brakes that are $40.00 oem pads for therear are around $65.00 front around a $100.00
Old Dec 4, 2007 | 08:38 AM
FALCOR's Avatar
well u shud b able to do another2 - 5000km from when the light comes on, depending on the quality pad u hav on. but if u have a ridge on the disk it will start to push on the ridge and not hard enuf on the disk , then u will loose braking pwr. replace then str8 away., i just did all my pads and front disks ,cost about R 1400 , think thats bout $ 200 or so. that was bosch and febi pads with a.t.e disks.
Old Dec 4, 2007 | 08:43 AM
FALCOR's Avatar
oh ye and if u do do it urself ,remember that in most cases the back piston pushes and turns in together to avoid damage.
Old Dec 4, 2007 | 09:30 AM
AWDaholic's Avatar
Senior Administrator
Depending on how many miles/week you rack up, I'd say you have 2, maybe 3 weeks (3000miles is a little HIGH of an estimate of remaining *functional* life, IMHO. maybe time until they grind, but you don't wat to take it THAT far), or about 1500 miles. I base my esitmate on personal experience with waiting too, too long until changing out the pads when the light comes on, on a couple different cars. Much longer than that and you risk scoring teh rotors.
Pads are an easy DIY.
Unless you are doing track-time, you do NOT need ceramic pads. Not that you mentioned it, but I just thought I'd throw it out there.
A VERY good set should run you $65-$85/axle -front, $45-$65/axle - rear.
Old Dec 4, 2007 | 10:28 AM
jerrod22's Avatar
So when my mechanic says $170 per axle for pads he's out of control? I appreciate all the feedback, thanks
Old Dec 4, 2007 | 05:56 PM
paaudia6's Avatar
Member
Not really that kinda cheap....the front and back should'nt be the same price tho because front padscost more then the rears do..
Old Dec 5, 2007 | 08:24 AM
FALCOR's Avatar
ye i guess it all depends on if u gona do long or short distance.
