Brake size
Old Mar 20, 2007 | 04:04 AM
jrrbritt's Avatar
Default Brake size
Hi all, I could use some help selecting brakes for my new Audi A6. its a 2003 2.7t quattro sedan. I would like to replace the front rotors, mostly because they make the car shake a bit when stopping (dealer turned them just before I bought it as a "favor" I guess, first time I drove it was before they did and no problems, just goes to show if it aint broke dont fix it! And if I take it back they will install their own cheapo OEM aftermarket rotors.). Also, I do some fairly spirited driving (dont we all?) and I would like to upgrade to drilled rotors. I am looking at the Zimmerman rotors and "green stuff" pads, any opinions?
My main problem is that I cant find a good resource for which rotors fit which cars, there seems to be some contradicotry ifo out there, especially for ths year and model. What size front do I need? The ones that are on there are vented if that helps. Also, whenI rplace them what is the torque spec for the rotors to hub? I know a good shop manual will probably have this info, but I'm impatient and mine hasnt arrived in the mail yet!
Any help would be much appreciated. Thanks!
Old Mar 20, 2007 | 05:40 AM
mustang196718's Avatar
Default RE: Brake size
ok, well i'm hoping that this will help you out some. i got this from a service manual, it's for your year, make, andmodel obviously. i can definitely see why there'd be conflicting info out there since it looks like they had a couple different sizes for your year. i'm wondering if the production number might be on your stock calipers or disks, then you'd be able to figure out which ones you needed. either that or you could always just go measure. it's either going to be a diameter of 288mm, 312, 321, or 365. as for the pads, my friend has the "green stuff" pads on his supra, and he loves them. as for the torque specs, i'm pretty sure it's just the wheel bolts that hold the rotor to the hub. i don't remember exactly to be honest, but in either case, the wheel bolt torque is supposed to be 120 Nm. ok, well hopefully my rambling helped you out a little bit.
-mike
'03 a6 2.7t front brake specs....
Old Mar 20, 2007 | 02:09 PM
WaggsA6's Avatar
I recently ordered the ebc sport rotors and ebc green stuff pads from www.autopartswarehouse.com. The rotor size is 321mm or 12.6 in. Haven't installed them yet as I still have some life left on the current pads so I can't give my opinion on them yet.
http://www.autopartswarehouse.com/pe...&partid=78
Old Apr 13, 2007 | 12:06 AM
massboykie's Avatar
Member
...there seems to be some contradicotry ifo out there, especially for ths year and model. What size front do I need?...
Hey Jrrbritt
I went through the same trouble a few months ago. I posted a lot of info for someone on VWVortex after I got mine done.
http://forums.vwvortex.com/zerothread?id=2995079
Some more here
http://forums.vwvortex.com/zerothread?id=2927399
Hope these help and aren't too late.
I suggest saving yourself a lot of hassle, by taking off a wheel from the front and rear and checking the part numbers off the rotors that are on the car. My PR codes suggested that the car had 245mm rears, but infact had 255s. My fronts are Zimmermanns and the rears Ate.
Cheers
Massboykie
mblayton
Sep 5, 2017 10:45 PM
jboldt420
Jul 11, 2008 03:51 PM
playboy00786
Jun 3, 2008 10:09 PM
greene08
Sep 6, 2007 07:05 PM
Ponch
Feb 1, 2007 02:59 PM
