which size of brake rotors?
Old Jun 1, 2008 | 05:57 PM
playboy00786's Avatar
Default which size of brake rotors?
im looking to buy new rotors since ive shaved them down for the last time but i dont know what size to get since they come in 3 different sizes for an 01 a6 2.7t..16" wheel....4 pad front caliper....they come in 288..312..321mm? So how do i know which size to get?
Old Jun 2, 2008 | 02:49 AM
Cmoney's Avatar
Default RE: which size of brake rotors?
You are gonna have the 321mm rotors on the front of that car. I got mine from this site. Check the linkhttp://www.germanpartsonline.com/catalog.html
this should help. It will show you how to check the build code.
Good luck
Old Jun 2, 2008 | 04:09 AM
liquidtuna's Avatar
321mm
Old Jun 2, 2008 | 09:22 PM
Now that i have which size they are now i need to know what type of clips the front pads use...also what would be a good kind to get?
Old Jun 2, 2008 | 09:33 PM
nothing77's Avatar
you may or may not have the 321mm, check to make sure that you have the Lucas/Girling HP2 calipers. These calipers use an 8 pad set. Or 4 per caliper. If you do have the HP2 calip[ers then the 321mm are your rotor sizes. Some A6 2.7t came with the ATE brake system which had smaller rotors ( I believe the 312mm)
Old Jun 3, 2008 | 10:09 PM
I have the 8 pad set...4 per caliper
adamsrotors
Jun 25, 2015 02:10 PM
adamsrotors
Jun 25, 2015 02:07 PM
